I have been searching for aftermarket rotors and I believe they are the same as BMW #34116757756 (95-01 BMW 750iL). Has anyone used these? The diameter, thickness, bolt pattern are correct. I cannot find the dimension on the hub diameter.
I shall be traveling for while but if no-one else has tried these I'll order a set and verify when I return. They are returnable in most cases. I think the chances are good that they will fit, obviously Bentley did not manufacture their own rotors and the whole brake system is BMW.
