OK, so its been a while since I posted and the car has been waiting for a gap in the work schedule but I finally got it back together today, but,.......
The reason I started this was because of low pressure in circuit 1. the low pressure light came on after about 6 pumps, but circuit 2 had a dodgy pressure switch so I couldn't really tell whether or not that side was low as well (yes I should have done a pressure test first before stripping it all off!)..
So, I fitted a re-conditioned sphere to circuit 1, from FS. I confirmed this was empty of nitrogen as I could push the charge valve and a small psst was heard, then nothing..
I decided to fit only one sphere as the circuit 2 sphere had a warranty sticker on from FS, and when I spoke to them quoting the number it was 3 years old, so I decided to take a chance and re-build the switch, then see how it was fitted.
I also rebuild both ACV's as well as both low pressure switches and front calipers.
So, the result?
Ignition on, both circuit 1 and 2 low pressure lights work and are on, a good start. Ran the car, lights went out almost straight away, pumps appeared to be quiet, got enough RR363 in the reservoir and after about 3-4 minutes the returns from both ACV's started working (could see the flow up from them in the reservoir).
All good? did the acid test. Car had been running for around 4 minutes, and I assumed that the ACV's must be working and system up to pressure as I could physically see the returns working. So, switched car off, ignition on, and began to pump the pedal.
Low pressure in circuit 1 after 39 pumps....Bugger......!
Low pressure in circuit 2 after about 110 pumps, well at least the second circuit sphere is ok.....!
So, I got a the last piece of the jigsaw for making the pressure test tool (Jaguar E Type series 1 front brake flex-hose), and set about testing the circuit 1 pressure.
I connected the gauge to the bleed nipple outlet in the circuit 1 ACV, and started the car.
Flick up pressure within 10 seconds 1000psi.
The gauge then rose steadily and after 3 1/2 minutes it had achieved 2300psi, then it dropped back to around 2000psi and seemed to settle there.
The figures suggested all is OK, so I switched off, then got someone to pump the pedal while I watched the gauge. After only about 20 pumps, and the gauge was going down a little bit each time the pedal was pumped, the gauge appeared to drop straight to zero. I released the bleed nipple on the gauge tool, just to check there was zero pressure, and there was. Started up again and it flicked up to 1000psi almost immediately again, then did the same, rose to 2300psi then dropped back to 2000psi.
Any ideas!?!?!?
Yours 'disappointedly',
Steve.
