Hello
I want (need) to replace the spheres on my accumulators. I've done the brake pedal pump test, and can only get 12 pumps before the warning lights come on. This is not a good situation. I understand that 30 pumps is a minimum and 60 pumps great.
Anyway, has anyone got a feeling which spheres to use. I reckon that I can fit normal Citroen CX type spheres (as these are the correct era) on the accumulators. As for the rear suspension ones, (assuming I go the whole way), I need to get proper RR ones, as I understand they are set to a special low pressure (~18 Bar), which is not available 'off the shelf' for the citroen.
Also, does anyone know what the difference is between the Citroen XM and the CX accumulator spheres?
Cheers... Rob.
Cheers... Rob.
