The 97 would have the battery in the siren, I'd remove the siren and inspect it to make sure that the battery has not damaged the siren itself and then replace the battery. You may need to re-code the fobs which will require the OMITEC tool or you can send your alarm module to introcar and they will repair it and send it back with two programmed fobs.
If you want more info, search "weekend wrenching and brooklands' I went through this dog and pony show with both my Brooklands and Arnage
