Bentley Turbo R, 1992
Hi all,
Currently living in Moscow and have just imported a 92 Turbo R. Unfortunately despite me adding washer fluid good for -20 the washer fluid pump isn’t working. The lines were frozen when I initially tried so I wonder if it might have blown a fuse or broken the pump? Even after a long drive from St Petersburg to Moscow the lines with the frozen fluid should have warmed up but the fluid still wouldn’t spray. I can’t find a washer pump fuse listen on the fuse panel. Has anyone got any advice on how I might fix this? When I push the stalk for a spray the wipers work but there is no liquid. Thanks in advance!
Check in the engine bay, left side under the plastic cover, there is a little box with some fuses including headlight and spray for headlight, I wonder if the fuse you look for is not there, or if same fuse for headlight. spray.
Looks like for MY92 it is a fuse C5 at fuseboard F1 (it is the left fuseboard above passenger legs).
Anyway, check washer pump connector just for corrosion.
29407
Hi both! Thanks so much for your advice. Will have a look based on it and see what I can do. Not at lot of spare parts in Moscow so hoping it’s easy enough to sort out!
It could be the pump itself too, either broken, either blocked, in this last case try to move the turbine with a thin tool
