1 - 7 of 7 Posts
During recent drive, notice smoke coming from under the hood.
The cause was green colored liquid leaking from somewhere in the front of the motor and dripping or spraying onto the passenger side exhaust pipe. Regrettably it was not antifreeze, but was/is mineral oil.
I have searched for a layout of the mineral oil circuit, to find out where all the components are located, but have been unsuccessful. Seeing the diagram would be very helpful before I start removing so many components.
If anyone has such information, your advice will be appreciated.
This might be a blessing, because I do need to address a leak in one of the reservoirs, and also a problem where the brakes are slow to engage and also release.
Thanks in advance.
Workshop manual and parts lists will show you where the parts are located and how to test and repair. Put in your VIN on this site to get info correct for your year and model: Home
There is also info on the Australian RROC technical site. See Tee One Topics there. Main Page - RROCA-info
There is a pump at the top of the V at the front behind the thermostat housing. That can blow to the sides onto the exhaust
1 - 7 of 7 Posts
