greetings friends, so as I said in the headline, when I put the gear lever into D is takes a while to engage if at all. It seems I need to go to L first. It also jerks quite a bit when I select any gear. What do you think it is? Cheers much, Marko
For starters, check the fluid level properly when warm and in Park when running. The trans depends on fluid level and pressure to make things happen.
