2000 Bentley Arnage Red Label looking for IETIS
1082 Views 24 Replies 5 Participants Last post by  vintik
Hello. Having several electrical and mechanical problems with a 2000 Bentley Arnage Red Label 6.75.
I cannot find a Bentley & Rolls-Royce ASSIST containing this particular model. Can you please tell me where can I buy this CD?
In exchange, I promise to share photos and a description of the repair of this car.
1 - 20 of 25 Posts
Hello, I purchased mine from Flying Spares, arrived on a nice wooden clad USB drive.
IETIS PARTS & WORKSHOP MANUAL - USB STICK (Seraph & Arnage) (P32150-USB)
Reactions: 1
Thank you, I'll try to negotiate a purchase.
Read fault codes
Green Azure Font Aqua Rectangle
P0115 Engine Coolant Temperature Sensor Circuit Malfunction
P0116 ECT Sensor Circuit Range/Performance
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0135 O2 Heater Circuit (B1S1)
See less See more
2
Automotive fuel system Motor vehicle Automotive exterior Auto part Automotive design
Motor vehicle Automotive tire Automotive design Automotive exterior Hood
See less See more
3
Gadget Communication Device Font Display device Electronic device
Temperature Font Telephony Communication Device Gadget
Car Motor vehicle Light Automotive lighting Amber
See less See more
Ah, the "lead plug" failure in a thermostat (as it doesn't look as though it's stuck shut). Once those plugs are out, the coolant is never going to get up to temperature since the coolant is running through the radiator from the moment the car is started.
I had one of those thermostats fail in precisely the same way in my Silver Wraith II. See: Thermostat Issues and Selection
Even Crewe eventually dropped this style in later years.
Reactions: 1
2
Thanks for the tip. I did not immediately understand how it works. I read the comment and decided to solder the holes.
Tomorrow I will get a new temperature sensor and check how it all works.
Automotive tire Motor vehicle Rim Gas Automotive wheel system
Automotive tire Automotive fuel system Motor vehicle Hood Automotive design
See less See more
2
While there is no temperature sensor, doing minor repairs. Replaced the filter in the fresh air sensor.
Font Automotive tire Wood Metal Office equipment
Automotive tire Motor vehicle Automotive lighting Hood Grille
See less See more
Have you tested the melting point of the solder plugs? This is a disaster in the making if it's too high and doesn't melt.You would have been better off with the Stant replacement in my opinion.
Reactions: 2
The car came to me with an unknown history. You can put in a new thermostat and it will leak again. While I collect it so that I can check other parts.
I would never put that thermostat back in unless I had done a boil test to make sure it is actually opening. These typically get stuck open rather than closed, but both have happened.
Even if I did put it back in during diagnostics, it would not be staying in there because there are inherent problems with this thermostat which are documented in the article I gave the link to earlier.
It's a way worse outcome if the thing sticks shut and the engine overheats than it is if it were stuck open (or the plugs are missing) and the engine runs cold, even though that's not good over the long term.
Reactions: 1
Thanks, that's a good point, especially when the thermostat is $7.
Of course, I checked the work of the thermostat before installation and I plan to very carefully monitor the temperature of the machine during the test.
If the result is positive, I will definitely install a new one.
Excuse me, but I had never repaired Bentley before, so some points are not clear to me. It’s good that anyone has to ask.
Which is but one reason you were very wise to have turned to a venue such as this, and have been carefully taking the advice on board.
These are not "typical" cars in a great many ways, and it's shocking just how screwed up they can become if repairs and maintenance are not performed correctly.
Crewe loved what I call "boutique engineering" on a lot of things where I think it would have been much better to have done just what everyone else was doing (and vice versa on a few things, but very few).
Reactions: 2
3
I did not write because there was no electricity and no internet. Another rocket attack.
Got a new temperature sensor.
Gas Auto part Cable Cylinder Machine
Installed and checked.
Brown Motor vehicle Wood Gauge Bird
The engine warmed up very quickly
Font Technology Electronic device Display device Screenshot
No more problem.
See less See more
Reactions: 1
Now it remains to deal with the oxygen sensor
Plant Gadget Font Electronic device Display device
See less See more
1 - 20 of 25 Posts
