hi the a/c switch marked screen/fascia on the right....is either broken or twisting round
so my question is how do I get the centre console wood veneer finisher off to get to the switch panel
thanks in advance
paul
Hi Paul, No need to get into the dash. The problem if most probably the tiny hex nut located on the dependent side of the switch. Just look up under the switch and you will see the recessed hex nut. Simply tighten it with the appropriate sized hex wrench and the switch will no longer spin without function. Mike
