Hello all. I recently bought a set of 17" wheels for my 93 Brooklands and am having fitment issues.
These are the wheels:
I believe these are from a Bentley Turbo RT and are the same wheels that Flying Spares is selling here: SET OF 17 They say they should fit my series of car.
The issue is that when I try to mount the front wheels, the grease cap hits the wheel center first, then it actually hits the wheel itself prior the wheel properly seating against the brake rotor.
This is the front hub:
My thought is that I would need some type of spacer between the wheel and the brake rotor. It would need to be a 5" x 155mm spacer, which does not exist in the marketplace, However, I do have a friend that is a master fabricator and could make that spacer; but then I'm wondering if I'll need longer wheel studs. The gap between the wheel and the brake rotor is around .3" or .4".
This is the car with it's current stock 15" wheels:
Any assistance is much appreciated.
Sincere Thanks,
Chuck C.
Sincere Thanks,
Chuck C.
