1 - 2 of 2 Posts
still playing with them jumped relay and horns good but don't have power to both legs , found wiring dia , and it says fuse panel 1 and panel 2 . found one on the right ,horn fuse in it is good , where should i go next? also no fuel pump pressure on my 71 . which side is it on?
It would help if:
1. You would give the full VIN or SZ Chassis Number Derivation from VIN for the car you're talking about here. That's the only way anyone can assist with any certainty.
2. Create a separate topic on the Shadow & Derivatives technical forum for your 1971 car, and give the full chassis number when you do.
These cars are not typical high production number vehicles and there were many changes that occurred at random times during the production runs. This can most clearly be seen for the earlier cars (up through the Shadow era) in the booklet, Chassis Number & Production Changes through SY Series.
It is utterly impossible to give any helpful or useful advice without specifics regarding the vehicle itself and the actual issue(s).
1 - 2 of 2 Posts
