1 - 2 of 2 Posts
Based on an article I read about air flow, I removed the covers for the air intake to the passenger compartment; the right side was relatively free of leaves and other debris, but the left side had an abundance of what appeared to be string mixed with foam. See the attached photo of what I removed! While I was at it, I repaired the black
plastic molding on the left side that the exterior chrome trim is attached to with some JB weld.
But I will be danged if I can attach the photo!!!!
Cheers!
There is a maximum size (in pixels and in MB) for photos. Try resizing down to 640x480 or 1024x768. You should then be able to drag and drop them to attach.
Forums were created well before the insanely high resolutions that even a smartphone can take, and the correspondingly huge file sizes, were anticipated. Not to mention that 1024x768 is generally more than large enough for online posting.
1 - 2 of 2 Posts
