1 - 8 of 8 Posts
Hello group,
I have a 1981 Sliver Spur (SCAZS42A9BCX03586) that will start and run, but after a few minutes, the engine will turn off. The engine will not restart till after it as cooled down. Checked and found that if the fuel pump relay in the trunk is jumped from 30 to 87, the engine will start and not die. I'm having trouble finding where terminal 86 goes to. It is white with an orange wire. The wiring diagrams that I found on http://rrtechnical.info/ do not show the terminals and have different colors on the wires. Also, I see in the passenger side fuse board that there is a piece of paper saying there is a thermal breaker to the right side of the board for the fuel pump. But I can not find it in the wiring diagrams. Thanks
The fuel pump has been replaced.
Thanks but that link takes me to the first page for this vehicle on rr technical, what chapter are you in?
1 - 8 of 8 Posts
