Hi all,
The rubber element of the flexible Steering Column Coupling (UR23270) has disintegrated, meaning the coupling needs to be renewed.
When trying to fit a new flexible coupling, it turned out that its holes for the four attachment bolts were some 4 mm further apart than the holes in the flanges of the adjoining steering column halves.
White Font Line Auto part Parallel
Assuming the dimensions of the new Steering Column Coupling are correct, is there a secret procedure on how to make it fit? Would it be advisable to compress the rubber element until the hole pattern matches (by for example tightening a hose clamp around it), or may the resulting radial forces damage the bolts or steering column flanges? Since the steering is indeed a safety critical part of your car, I am not keen on improvising on this.
Best Regards, Anders
1971 Bentley T
Since nobody has replied yet, I might add a thought:
I remember from long ago replacing rubber donuts on drive shafts - they were always supplied crushed by a metal band which was to be cut off after assembly. This was, I assume , to ensure that the rubber bits were always in compression, not tension, but the stresses on a steering column are not in the same league???
An alternative is that there are more than one size of doughnut on cars of different years???
Alan D.
I think the same manufacturer has been trying to sub the MG(?) part for the RR. It is very close and can work, but not ideal. I seem to recall an issue with these and there should be something archived here. Do a search.
The RR coupler has not changed over the years.
