Hello,
I have a 1977 Silver Shadow II and I've caused myself an issue. I was updating the alternator and while checking to see which wire ran generator light I bumped Alternator feed wire in to block. It blew something because now I have no power at the ignition switch, it won't start and no headlights. Glove box light is still going. I checked all the fuses under the glove box and none has blown. I've searched for other fuse blocks but have not located any. It appears the Alt feed wire runs right under the steering column which is where everything is dead. This is a right-hand drive car if that makes a difference. If you have any ideas where I might start looking I'd very much appreciate it.
thanks for reading post,
