Remove the lower radiator hose.
I find that a bit too fast (and messy) myself. I take out the actual drain valve (and I do mean I remove it, which is easy. They often stick and break if you actually attempt to open the valve, which has a tiny, tiny drain tube at its center). That drains the system quickly, but in a more controlled manner.
