If the pistons have been forced back as Jim describes, with the rusted part now inside the cylinder, the only way to get them out may be:-
1) to remove them from the car,
2) block all the fluid holes except one,
30 drill right through a spare bleed nipple,
4) screw that tight into the last hole,
5) fill a high pressure grease-gun with grease,
6) force grease into the unit till the piston moves.
If it doesn't move use MORE PRESSURE.
Alan D.
