Hi All haven't been successful finding .145 OD line to go to leveling valves on my 91 Silver spur2 any guidance would be appreciated as the car can't move now with lines off of car. I'm in Ontario Canada thanks in advance
Tom
Could it be .125 without the green coating? I think the fittings are metric by that year so the tube may be also. Here is one source for 1/8th OD tubing although it's stainless.
Check with a company local to you that makes up hydraulic hoses. Broaden your search for oil pressure line perhaps. Last ditch have some stainless braided hoses made up with each end turned down to .145 OD then you can use the original tube nut and rubber olive to fasten to the height control valve. Simply block off the height control so you can move the car if you need to. I have a couple late Spurs in the shop but wouldn't be able to have a look at the lines and fittings on them until later on the weekend.
