After dealing with various cooling system leaks y car developed a new hydraulic system leak in one of the accumulators. That was fixed and brakes bled but then we had a hydraulic pressure spike and one of my hydraulic system pumps bent its needle. That required disassembly of the intake system to get it out and fix it. What a nightmare. Now with that all off we are also replacing the valve cover gaskets. Any idea why we would have a pressure spike in the system that would cause that? This car has been a horrible money pit. Much worse than my ‘88 was…
29891
29892
29893
29894
A brake pump pushrod failure would be caused by a seized accumulator valve, or a seized brake pump. Did the shop replace the leaking accumulator valve with a new, used, or rebuilt valve? Did the pushrod bend right after rectifying the accumulator valve leak?
Begs the question, why didn't they replace the pressure valve at the same time, and or test with a gauge at the pressure valve before or after the accumulator replacement.
Now it's removal time and replacement at the customers' expense.
I suspect they installed a faulty accumulator valve or didn't overhaul it properly if they rebuilt it themselves. Have you asked about that?
Make sure they replace the intake runner O rings with new, they are a common source of vacuum leaks. Also make sure they use Hylomar or Loctite anaerobic sealant for the valley cover, not silicone.
