Main    FAQ    Search    Links    Photo Gallery    Memberlist   Register    Profile    Log in to check your private messages    Log in
1991 bentley turbo r red label problem
Start new topic   Reply to topic    Rolls-Royce and Bentley Home -> SY Series I and II 1965-1980
View previous topic :: View next topic
Author Message
allforfun
New Member
PostPosted: Fri Aug 05, 2011 8:01 am    Post subject: 1991 bentley turbo r red label problem Reply with quote
ive got a 1991 bentley turbo r red label with a strange problem one minute it runs fine the next it will not start at all ,then finally it will start cough and splutter a bit then run fine again until the next time it does it, ive changed all the plugs , distibuter caps, two coils, rotor arms im at a loss as to what the fault is , its as if the car is not firing at all yet then all of a sudden it goes, its not petrol, as petrol is up straight away and at the plugs as they are getting wet its as if theres an immobaliser on it and it kicks in im really at a loss also when this fault happens the management light comes on saying engine fault then goes back of when it starts running again is there anyway i can get this diagnostic checked ? or any ideas as to what the fault is ?
Back to top
View user's profile Send private message
RollsRoyceForums.com
Advertisement
rollmech
Phantom
PostPosted: Fri Aug 05, 2011 12:29 pm    Post subject: Re: 1991 bentley turbo r red label problem Reply with quote
Sounds very much like you have a connection/sensor fault if you follow the link listed on many other post for the australian RR owners club they have the manuals which will have all info on how to check them
Back to top
allforfun
New Member
PostPosted: Fri Aug 05, 2011 4:16 pm    Post subject: Reply with quote
where do i find the info on that ? ive had a look but cannot see ? any other ideas ? its a very strange fault
Back to top
1936PIII
New Member
PostPosted: Fri Aug 05, 2011 6:55 pm    Post subject: DIP Reply with quote
you might have a Driver Information Panel problem, its becoming more and more common with this era of rolls and bentley. the DIP is between your 2 main guages in the dash and ALL the cars info passes through it when you turn the key on. if the panel starts to fail you will get intermitent problems just like you describe. are you getting any odd codes flashing up then disappearing? if it is the DIP then sooner or later it will just die and you won`t even be able to get the car out of park. they are an absolute bugger and bosche don`t make then anymore. let me know the answer to above question.
cheers, david.
_________________
Untrinque Paratus.
Back to top
View user's profile Send private message AIM Address
Hemmo
Phantom
PostPosted: Mon Aug 08, 2011 1:22 pm    Post subject: Reply with quote
Have you replaced the ignition-leads, contact points, ignition module? Rolling Eyes
Arrow
_________________
Could it be a little more perhaps......no, it MUST be more!
Back to top
View user's profile Send private message MSN Messenger
Display posts from previous:
Start new topic   Reply to topic    Rolls-Royce and Bentley Home -> SY Series I and II 1965-1980 All times are GMT - 5 Hours
Page 1 of 1
Jump to:
You cannot start new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Copyright © 2006 RollsRoyceForums.com
RollsRoyceForums.com is in no way affiliated with Rolls-Royce plc, BMW AG, Rolls-Royce Motor Cars Limited, Bentley Motors Ltd., or Volkswagen AG. Rolls-Royce, the "RR" logo, the radiator grille, and the Spirit of Ecstasy are registered trade marks exclusively licensed to Rolls-Royce Motor Cars Limited. Bentley is a registered trademark of Bentley Motors Ltd.
Powered by phpBB © 2001, 2005 phpBB Group - Design: niedermayr.cc for phpbbstyles.eu
Guild Wars © 2004 ArenaNet, Inc. All rights reserved. ArenaNet, Arena.Net and the ArenaNet logo are trademarks or registered trademarks of NCsoft Corporation in the U.S. and/or other countries.
